interface-config-radio-instance
Enables support for Low Density Parity Check (LDPC) codes on the radio interface
LDPC consists of forward error correcting codes that enable error control in data transmission. This option is disabled by default.
ldpc
None
nx9500-6C8809(config-profile-Test510-if-radio1)#ldpc nx9500-6C8809(config-profile-Test510-if-radio1)#show context interface radio1 ldpc nx9500-6C8809(config-profile-Test510-if-radio1)#
| no (radio-interface-config-command) | Disables LDPC support |
