autoinstall
Profile Config Commands
Automatically installs firmware image and startup configuration parameters on to the selected device.
- Access Points — AP410i/e, AP460i/e, AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562,
AP7612, AP7632, AP7662, AP8432, AP8533
- Service Platforms
— NX5500, NX7500, NX9500, NX9600, VX9000
autoinstall [configuration|firmware|start-interval <WORD>]
Parameters
| configuration |
Autoinstalls
startup configuration. Setup parameters are automatically configured on
devices using this profile. This option is disabled by default. |
| firmware |
Autoinstalls
firmware image. Firmware images are automatically installed on devices using
| start-interval
<WORD> |
Configures the
interval between system boot and start of autoinstall process (this is the
time, from system boot, after which autoinstall should start) |
nx9500-6C8809(config-profile-default-ap505)#autoinstall configuration
nx9500-6C8809(config-profile-default-ap505)#autoinstall firmware
nx9500-6C8809(config-profile-default-ap505)#show context include-factory | inclu
de autoinstall
no autoinstall firmware
autoinstall start-interval 10
Related Commands
| no |
Disables the auto install settings |
