customize [cdp-lldp-info-column-width|hostname-column-width|show-adoption-status| show-wireless-client|show-wireless-client-stats|show-wireless-client-stats-rf| show-wireless-meshpoint|show-wireless-meshpoint-accelerated-multicast| show-wireless-meshpoint-neighbor-stats|show-wireless-meshpoint-neighbor-stats-rf| show-wireless-mint-client|show-wireless-mint-client-stats| show-wireless-mint-client-stats-rf|show-wireless-mint-portal| show-wireless-mint-portal-stats|show-wireless-mint-portal-stats-rf| show-wireless-radio|show-wireless-radio-stats|show-wireless-radio-stats-rf]
customize [cdp-lldp-info-column-width|hostname-column-width] <1-64>
customize show-adoption-status (adopted-by,ap-name <1-64>,cdp-lldp-info, config-status,last-adoption,msgs,uptime,version)
customize show-wireless-client (ap-name <1-64>,auth,client-identity <1-32>,bss, enc,hostname <1-64>,ip,last-active,location <1-64>,mac,radio-alias <3-67>,radio-id, radio-type,role <1-32>,state,username <1-64>,vendor,vlan,wlan)
customize show-wireless-client-stats (hostname <1-64>,mac,rx-bytes,rx-errors, rx-packets,rx-throughput,t-index,tx-bytes,tx-dropped,tx-packets,tx-throughput)
customize show-wireless-client-stats-rf (average-retry-number,error-rate, hostname <1-64>,mac,noise,q-index,rx-rate,signal,snr,tx-rate)
customize show-wireless-meshpoint-accelerated-multicast (ap-hostname,group-addr,mesh-name,neighbor-hostname,neighbor-ifid,radio-alias, radio-id,radio-mac,subscriptions)
customize show-wireless-meshpoint (ap-mac,cfg-as-root,hops,hostname <1-64>, interface-ids,is-root,mesh-name <1-64>,mpid,next-hop-hostname <1-64>,next-hop-ifid, next-hop-use-time,path-metric,root-bound-time,root-hostname <1-64>,root-mpid)
customize show-wireless-meshpoint-neighbor-stats (ap-hostname <1-64>, neighbor-hostname <1-64>,neighbor-ifid,rx-bytes,rx-errors,rx-packets,rx-throughput, t-index,tx-bytes,tx-dropped,tx-packets,tx-throughput)
customize show-wireless-meshpoint-neighbor-stats-rf (ap-hostname <1-64>, average-retry-number,error-rate,neighbor-hostname <1-64>,neighbor-ifid,noise,q-index, rx-rate,signal,snr,t-index,tx-rate)
customize show-wireless-mint-client (client-alias <1-64>,client-bss, portal-alias <1-64>,portal-bss,up-time)
customize show-wireless-mint-client-stats (client-alias <1-64>, portal-alias <1-64>,portal-bss,rx-bytes,rx-errors,rx-packets,rx-throughput,t-index, tx-bytes,tx-dropped,tx-packets,tx-throughput)
customize show-wireless-mint-client-stats-rf (average-retry-number, client-alias <1-64>,error-rate,noise,portal-alias <1-64>,portal-bss,q-index,rx-rate, signal,snr,tx-rate)
customize show-wireless-mint-portal (client-alias <1-64>,client-bss, portal-alias <1-64>,portal-bss,up-time)
customize show-wireless-mint-portal-stats (client-alias <1-64>,client-bss, portal-alias <1-64>,rx-bytes,rx-errors,rx-packets,rx-throughput,t-index,tx-bytes, tx-dropped,tx-packets,tx-throughput)
customize show-wireless-mint-portal-stats-rf (average-retry-number, client-alias <1-64>,client-bss,error-rate,noise,portal-alias <1-64>,q-index,rx-rate, signal,snr,tx-rate)
customize show-wireless-radio (adopt-to,ap-name <1-64>,channel,location <1-64>, num-clients,power,radio-alias <3-67>,radio-id,radio-mac,rf-mode,state)
customize show-wireless-radio-stats (radio-alias <3-67>,radio-id,radio-mac, rx-bytes,rx-errors,rx-packets,rx-throughput,tx-bytes,tx-dropped,tx-packets, tx-throughput)
customize show-wireless-radio-stats-rf (average-retry-number,error-rate, noise,q-index,radio-alias <3-67>,radio-id,radio-mac,rx-rate,signal,snr,t-index, tx-rate)
| hostname-column-width <1-64> | Configures default width of the hostname column in all show commands
| cdp-lldp-info-column-width <1-64> | Configures the column width in the command output
| show-adoption-status | Configures the information displayed in the show > adoption > status
command output. Select the columns (information) displayed from the
following options: adopted-by, ap-name, cdp-lldp-info, config-status,
last-adoption, msgs, uptime, and version. These are recursive parameters and
you can select multiple options at a time. The columns displayed by default are: Device-Name, Version, Config-Status, MSGS, Adopted-By, Last-Adoption, and Uptime. Where ever available, you can optionally use the <1-64> parameter to set the column width. |
customize show-wireless-client (ap-name <1-64>,auth,client-identity <1-32>, bss,enc,hostname <1-64>,ip,last-active,location <1-64>,mac,radio-alias <3-67>, radio-id,radio-type,role <1-32>,state,username <1-64>,vendor,vlan,wlan)
| show-wireless-client | Customizes thecommand output The columns displayed by default are: MAC, IPv4, Vendor, Radio-ID, WLAN. VLAN, and State. |
| ap-name <1-64> | Includes the ap-name column, which displays the name of the AP with
which this client associates
| auth | Includes the auth column, which displays the authorization protocol used by the wireless client |
| client-identity <1-32> | Includes the client-identity (device type) column, which displays
details gathered from DHCP device fingerprinting feature (when enabled). For
more information, see client-identity.
| bss | Includes the BSS column, which displays the BSS ID the wireless client is associated with |
| enc | Includes the enc column, which displays the encryption suite used by the wireless client |
| hostname <1-64> | Includes the hostname column, which displays the wireless client's
hostname
| ip | Includes the IP column, which displays the wireless client's current IP address |
| last-active | Includes the last-active column, which displays the time of last activity seen from the wireless client |
| location <1-64> | Includes the location column, which displays the location of the
client's associated Access Points
| mac | Includes the MAC column, which displays the wireless client's MAC address |
| radio-alias <3-67> | Includes the radio-alias column, which displays the radio alias with the
AP's hostname and radio interface number in the "HOSTNAME:RX" format
| radio-id | Includes the radio-id column, which displays the radio ID with the AP's MAC address and radio interface number in the "AA-BB-CC-DD-EE-FF:RX" format |
| radio-type | Includes the radio-type column, which displays the wireless client's radio type |
| role <1-32> | Includes the role column, which displays the client's role
| state | Includes the state column, which displays the wireless client's current availability state |
| username <1-64> | Includes the username column, which displays the wireless client's
username
| vendor | Includes the vendor column, which displays the wireless client's vendor ID |
| vlan | Includes the VLAN column, which displays the wireless client's assigned VLAN |
| wlan | Includes the WLAN column, which displays the wireless client's assigned WLAN |
| show-wireless-client-stats | Customizes the stats command output The columns displayed by default are: MAC, Tx bytes, RX bytes, Tx pkts, Rx pkts, and Tx bps, RX bps, T-Index, and Dropped pkts. |
hostname
| rx-bytes | Includes the rx-bytes column, which displays the total number of bytes received by the wireless client |
| rx-errors | Includes the rx-error column, which displays the total number of errors received by the wireless client |
| rx-packets | Includes the rx-packets column, which displays the total number of packets received by the wireless client |
| rx-throughput | Includes the rx-throughput column, which displays the receive throughput at the wireless client |
| t-index | Includes the t-index column, which displays the traffic utilization index at the particular wireless client |
| tx-bytes | Includes the tx-bytes column, which displays the total number of bytes transmitted by the wireless client |
| tx-dropped | Includes the tx-dropped column, which displays the total number of dropped packets by the wireless client |
| tx-packets | Includes the tx-packets column, which displays the total number of packets transmitted by the wireless client |
| tx-throughput | Includes the tx-throughput column, which displays the transmission throughput at the wireless client |
customize show-wireless-client-stats-rf (average-retry-number,error-rate,noise, q-index,rx-rate,signal,snr,t-index,tx-rate)
| show-wireless-client-stats-rf | Customizes the stats RF command output The columns displayed by default are: MAC, Signal (dBm), Noise (dBm), SNR (dB), TX Rate (Mbps), Retry Avg, Errors (pps), and Q-Index (%). |
| average-retry-number | Includes the average-retry-number column, which displays the average number of retransmissions made per packet |
| error-rate | Includes the error-rate column, which displays the rate of error for the wireless client |
hostname
| noise | Includes the noise column, which displays the noise (in dBm) as detected by the wireless client |
| q-index | Includes the q-index column, which displays the RF quality
index Note: Higher values indicate better RF quality.
| rx-rate | Includes the rx-rate column, which displays the receive rate at the particular wireless client |
| signal | Includes the signal column, which displays the signal strength (in dBm) at the particular wireless client |
| snr | Includes the snr column, which displays the signal-to-noise (SNR) ratio (in dB) at the particular wireless client |
| tx-rate | Includes the tx-rate column, which displays the packet transmission rate at the particular wireless client |
customize show-wireless-meshpoint-accelerated-multicast (ap-hostname,group-addr, mesh-name,neighbor-hostname,neighbor-ifid,radio-alias,radio-id,radio-mac,subscriptions)
| show-wireless-meshpoint-accelerated-multicast | Configures the information displayed in the command output. Select the columns (information) displayed
from the following options: ap-hostname, group-addr, mesh-name,
neighbor-hostname, neighbor-ifid, radio-alias, radio-id, radio-mac,
subscriptions. These are recursive parameters and you can select multiple
options at a time. The columns displayed by default are: Mesh, Radio, Neighbor-IFID, Neighbor-Hostname, Group-MAC, and Subscriptions. |
| show-wireless-meshpoint | Customizes the command output The columns displayed by default are: Mesh, Hostname, Hops, Is-Root, Config-As-Root, Root-Hostname, Root-Bound-Time, Path-Metric, Next-Hop-Hostname, and Next-Hop-Use-Time. |
| ap-mac | Includes the ap-mac column, which displays the AP's MAC address in the AA-BB-CC-DD-EE-FF format. Applicable only in case of non-wireless controller meshpoints |
| cfg-as-root | Includes the cfg-as-root column, which displays the configured root state of the meshpoint |
| hops | Includes the hops column, which displays the number of hops to the root for this meshpoint |
| hostname <1-64> | Includes the hostname column, which displays the AP's hostname.
| interface-ids | Includes the interface-ids column, which displays the interface identifiers (interfaces used by this meshpoint) |
| is-root | Includes the is-root column, which displays the current root state of the meshpoint |
| mesh-name <1-64> | Includes the mesh-name column, which displays the meshpoint's name
| mpid | Includes the mpid column, which displays the meshpoint identifier in the AA-BB-CC-DD-EE-FF format |
| next-hop-hostname <1-64> | Includes the next-hop-hostname column, which displays the next-hop AP's
name (the AP next in the path to the bound root)
| next-hop-ifid | Includes the next-hop-ifid column, which displays the next-hop interface identifier in the AA-BB-CC-DD-EE-FF format |
| next-hop-use-time | Includes the next-hop-use-time column, which displays the time since this meshpoint started using this next hop |
| root-bound-time | Includes the root-bound-time column, which displays the time since this meshpoint has been bound to the current root |
| root-hostname <1-64> | Includes the root-hostname column, which displays the root AP's hostname
to which this meshpoint is bound
| root-mpid | Includes the root-mpid column, which displays the bound root meshpoint identifier in the AA-BB-CC-DD-EE-FF format |
customize show-wireless-meshpoint-neighbor-stats (ap-hostname <1-64>, neighbor-hostname <1-64>,neighbor-ifid,rx-bytes,rx-errors,rx-packets,rx-throughput,t-index, tx-bytes,tx-dropped,tx-packets,tx-throughput)
| show-wireless-meshpoint-neighbor-stats | Customizes the command output The columns displayed by default are: AP Hostname, Neighbor-IFID, TX bytes, RX bytes, Tx pkts, Rx pkts, Tx (bps), Rx (bps), T-Index (%), and Dropped pkts. |
| ap-name <1-64> | Includes the ap-name column, which displays name of the AP reporting a
neighbor
| neighbor-hostname <1-64> | Includes the neighbor-hostname column, which displays the reported
neighbor's hostname
| neighbor-ifid | Includes the neighbor-ifid column, which displays the neighbor's interface ID |
| rx-bytes | Includes the rx-bytes column, which displays the total bytes received |
| rx-errors | Includes the rx-error column, which displays the total bytes of error received |
| rx-packets | Includes the rx-packets column, which displays the number of packets received |
| rx-throughput | Includes the rx-throughput column, which displays neighbor's received throughput |
| t-index | Includes the t-index column, which displays the traffic utilization index at the neighbor end |
| tx-bytes | Includes the tx-bytes column, which displays the total bytes transmitted |
| tx-dropped | Includes the tx-dropped column, which displays the total bytes dropped |
| tx-packets | Includes the tx-packets column, which displays the number of packets transmitted |
| tx-throughput | Includes the tx-throughput column, which displays neighbor's transmitted throughput |
customize show-wireless-meshpoint-neighbor-stats-rf (ap-hostname <1-64>, average-retry-number,error-rate,neighbor-hostname <1-64>,neighbor-ifid,noise, q-index,rx-rate,signal,snr,t-index,tx-rate)
| show-wireless-meshpoint-neighbor-stats-rf | Customizes the command output The columns displayed by default are: AP Hostname, Neighbor-IFID, Signal (dBm), Noise (dBm), SNR (dB), Tx-Rate (Mbps), Rx-Rate (Mbps), Retry Avg, Errors (pps), and Q-Index (%). |
neighbor
| average-retry-number | Includes the average-retry-number column, which displays the average number of retransmissions made per packet. |
| error-rate | Includes the error-rate column |
| neighbor-hostname <1-64> | Includes the neighbor-hostname, which displays reported neighbor's
hostname
| noise | Includes the noise column, which displays the noise level in dBm |
| q-index | Includes the q-index column, which displays the q-index |
| rx-rate | Includes the rx-rate column, which displays rate of receiving |
| signal | Includes the signal column, which displays the signal strength in dBM |
| snr | Includes the snr column, which displays the signal-to-noise ratio |
| t-index | Includes the t-index column, which displays t-index |
| tx-rate | Includes the tx-rate column, which displays rate of transmission |
customize show-wireless-mint-client (client-alias <1-64>,client-bss,portal-alias <1-64>,portal-bss,up-time)
| show-wireless-mint-client | Configures the information displayed in the command output. Select the columns (information) displayed
from the following options: client-alias, client-bss, portal-alias,
portal-bss, and up-time. These are recursive parameters and you can select
multiple options at a time. The columns displayed by default are: Portal, Portal-Radio-MAC, Client, Client-Radio-MAC, and Up-Time. |
customize show-wireless-mint-client-stats (client-alias <1-64>,portal-alias <1-64>, portal-bss,rx-bytes,rx-errors,rx-packets,rx-throughput,t-index,tx-bytes,tx-dropped, tx-packets,tx-throughput)
| show-wireless-mint-client-stats | Configures the information displayed in the command output. Select the columns (information) displayed
from the following options: client-alias, portal-alias, portal-bss,
rx-bytes, rx-errors, rx-packets, rx-throughput, t-index, tx-bytes,
tx-dropped, tx-packets, tx-throughput. These are recursive parameters and
you can select multiple options at a time. The columns displayed by default are: Portal, Portal-Radio-MAC, Client, Tx bytes, Rx bytes, TX pkts, Rx pkts, TX (bps), Rx (bps), T-Index (%), and Dropped pkts. Where ever available, you can optionally use the <1-64> parameter to set the column width. |
| show-wireless-mint-client-stats-rf | Configures the information displayed in the command output. Select the columns (information) displayed
from the following options: average-retry-number, client-alias, error-rate,
noise, portal-alias, portal-bss, q-index, rx-rate, signal, snr, and tx-rate.
These are recursive parameters and you can select multiple options at a
time. The columns displayed by default are: MAC, Signal (dBm), Noise (dBm), SNR (dB), Tx-Rate (Mbps), Rx-rate (Mbps), Retry Avg, Errors (pps), and Q-Index (%). Where ever available, you can optionally use the <1-64> parameter to set the column width. |
| show-wireless-mint-portal | Configures the information displayed in the command output. Select the columns (information) displayed
multiple options at a time. The columns displayed by default are: Client, Client-Radio-MAC, Portal, Portal-Radio-MAC, and Up-Time. Where ever available, optionally use the <1-64> parameter to set the column width. |
| show-wireless-mint-portal-stats-rf | Configures the information displayed in the command output. Select the columns (information) displayed
from the following options: average-retry-number, client-alias, client-bss,
error-rate, noise, portal-alias, q-index, rx-rate, signal, snr, tx-rate.
time. The columns displayed by default are: Client, Client-Radio-MAC, Portal, Signal (dBm), Noise (dBm), SNR (dB), Tx-Rate (Mbps), Rx-rate (Mbps), Retry Avg, Errors (pps), and Q-Index (%). Where ever available, optionally use the <1-64> parameter to set the column width. |
| show-wireless-radio | Customizes the show wireless radio command output |
| adopt-to | Includes the adopt-to column, which displays information about the wireless controller adopting this AP |
| ap-name <1-64> | Includes the ap-name column, which displays information about the AP
this radio belongs
| channel | Includes the channel column, which displays information about the configured and current channel for this radio |
| location <1-64> | Includes the location column, which displays the location of the AP this
radio belongs
| num-clients | Includes the num-clients column, which displays the number of clients associated with this radio |
| power | Includes the power column, which displays the radio's configured and current transmit power |
| radio-alias <3-67> | Includes the radio-alias column, which displays the radio's alias
(combination of AP's hostname and radio interface number in the
"HOSTNAME:RX" formate)
| radio-id | Includes the radio-id column, which displays the radio‘s ID (combination of AP's MAC address and radio interface number in the "AA-BB-CC-DD-EE-FF:RX" format) |
| radio-mac | Includes the radio-mac column, which displays the radio's base MAC address |
| rf-mode | Includes the rf-mode column, which displays the radio's operating mode. The radio mode can be 2.4 GHz, 5.0 GHz, or sensor. |
| state | Includes the state column, which displays the radio's current operational state |
| show-wireless-radio-stats | Customizes the show wireless radio statistics command output |
"HOSTNAME:RX" format)
| rx-bytes | Includes the rx-bytes column, which displays the total number of bytes received by the radio |
| rx-errors | Includes the rx-error column, which displays the total number of errors received by the radio |
| rx-packets | Includes the rx-packets column, which displays the total number of packets received by the radio |
| rx-throughput | Includes the rx-throughput column, which displays the receive throughput at the radio |
| tx-bytes | Includes the tx-bytes column, which displays the total number of bytes transmitted by the radio |
| tx-dropped | Includes the tx-dropped column, which displays the total number of packets dropped by the radio |
| tx-packets | Includes the tx-packets column, which displays the total number of packets transmitted by the radio |
| tx-throughput | Includes the tx-throughput column, which displays the transmission throughput at the radio |
customize show-wireless-radio-stats-rf (average-retry-number,error-rate,noise, -index,radio-alias <3-67>,radio-id,radio-mac,rx-rate,signal,snr,t-index,tx-rate)
| show-wireless-radio-stats-rf | Customizes the show wireless radio stats RF command output |
| average-retry-number | Includes the average-retry-number column, which displays the average number of retransmissions per packet |
| error-rate | Includes the error-rate column, which displays the rate of error for the radio |
| noise | Includes the noise column, which displays the noise detected by the radio |
| rx-rate | Includes the rx-rate column, which displays the receive rate at the particular radio |
| signal | Includes the signal column, which displays the signal strength at the particular radio |
| snr | Includes the snr column, which displays the signal-to-noise ratio at the particular radio |
| t-index | Includes the t-index column, which displays the traffic utilization index at the particular radio |
| tx-rate | Includes the tx-rate column, which displays the packet transmission rate at the particular radio |
The following example shows the shows the show > adoption > status command output before customizing the output:
NX7500-160C09#show adoption status
Adopted by:
Type : nx9000
System Name : nx9500-6C8809
MAC address : B4-C7-99-6C-88-09
MiNT address : 19.6C.88.09
Time : 4 days 22:38:32 ago
Adopted Devices:
DEVICE-NAME VERSION CFG-STAT MSGS ADOPTED-BY LAST-ADOPTION UPTIME
ap7532-A2A56C 7.3.0.0-005D configured No NX7500-160C09 4 days 22:25:56 4 days 22:31:23
Total number of devices displayed: 1
NX7500-160C09#
NX7500-160C09(config)#customize show-adoption-status adopted-by ap-name config-status last-adoption NX7500-160C09(config)#commit
The following example shows the shows the show > adoption > status command output after customizing the output:
Adopted by:
Type : nx9000
Time
Adopted Devices:
ADOPTED-BY DEVICE-NAME CFG-STAT LAST-ADOPTION
NX7500-160C09 ap7532-A2A56C configured 4 days 22:25:56
Use the command to revert back to the default format.
NX7500-160C09(config)#no customize show-adoption-status NX7500-160C09(config)#commit
Adopted by:
Type : nx9000
Adopted Devices:
NX7500-160C09#
| no | Restores custom CLI settings to default |
