ebgp-multihop (bgp-neighbor-config)
Enables eBGP Multihop on this BGP neighbor. When enabled, allows
neighbor connection to be established between two eBGP neighbors that are not directly
connected to each other. Use this command to configure the maximum number of hops possible
between two such eBGP neighbors. This option is disabled by default.
- Service Platforms — NX9500, NX9600
Syntax
ebgp-multihop <1-255>
Parameters
| ebgp-multihop <1-255> |
Configures the maximum number of hops that can be
between eBGP neighbors not directly connected to each other.
- <1-255> – Specify a value from 1 - 255. The default is 255.
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#ebgp-multihop 20
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context
bgp neighbor 192.168.13.99
advertisement-interval 100
allowas-in 10
attribute-unchanged as-path
capability orf prefix-list both
default-originate
description neighbor "This neighbor is an external AS neighbor"
disable-connected-check
dont-capability-negotiate
ebgp-multihop 20
