Changes the next boot partition or image on a specified device or on the logged device. The WiNG devices have two partitions: primary and secondary, with each partition containing an image of the operating system. Whenever the device boots up it loads the image from the partition specified here.
The partition currently in control of the boot process is the active partition, the other partition is the inactive partition with the alternate image. Use this command to manually change the next boot partition or image.
boot system [active|inactive|primary|secondary] {on <DEVICE-NAME>}
| system [active|inactive|primary|secondary] | Specifies the image used by the device to boot up
Note: You will need to
reload the device in order for the change to take effect.
| on <DEVICE-NAME> | Optional. Changes the next boot image or partition on a specified
device
Note: If no device is
specified, the logged device's next boot-up configuration is
changed.
ap510-133B38#show boot
IMAGE BUILD DATE INSTALL DATE VERSION
Primary 09/05/2019 23:15:52 08/17/2019 18:40:41 7.2.1.0-012B
Secondary 09/10/2019 05:08:06 08/22/2019 11:05:43 7.2.1.0-013B
Current Boot : Primary
Next Boot : Secondary
Software Fallback : Enabled
ap510-133B38#
ap510-133B38#boot system primary Updated system boot partition ap510-133B38#
Next Boot : Primary
ap510-133B38#
