Connecting Power to the Switch
Connect the power cord (included) to the AC power
input socket on the switch or power supply.
Connect the other end to an AC power outlet.
- If applicable, attach the cable from your external (redundant) power supply to the switch‘s RPS receptacle.
- When power is connected, verify that the PW LED turns green.
After verifying that the switch has powered up properly, follow the instructions in Connecting Network Interface Cables.
If the PW LED does not turn green, see ExtremeSwitching 210 and 220 Series Switch LEDs for troubleshooting information.
