Power Cord Requirements for AC-Powered Switches and AC Power
Supplies
An AC power cord is not included with the AC power supply.
Power cords used with AC-powered switches or with Summit AC power
supplies must meet the following requirements:
- The power cord must be agency-certified for the country of
use.
- The power cord must have an IEC320-C13 connector for
connection to the switch or power supply.
- The power cord must have an appropriately rated and approved
wall plug applicable to the country of installation.
- For cords up to 6 feet (2 m) long, the wire size must be 18
AWG (.75 mm2) minimum; over 6 feet, the
minimum wire size is 16 AWG (1.0 mm2).
You can purchase AC power cords for use in the US and Canada from Extreme Networks or from your
local supplier.
