The RPS-500p (model 10923) is a 500 watt DC power redundant power supply for use with Extreme 802.3at PoE-compliant stackable or standalone switches. The RPS-500p is a standalone unit that can be rack mounted in a standard 19-inch rack.
The power supply provides power backup to an Extreme stackable or standalone fixed switch. If for some reason the switch loses power from its internal power supply, the RPS-500p can provide up to 500 watts maximum operating power to support switch operation and the 55 VDC necessary to support 55 VDC/data connections to PDs (powered devices). The RPS-500p has one 2x7 power connector.
RPS-500p LED Status Definitions
| Power LED | Meaning | Recommended Action |
Green, solid |
AC input to power supply is within specifications |
None |
Off |
AC input power to power supply is out of specification. |
For technical specifications, see RPS-500p Redundant Power Supply Technical Specifications.
