Battery Replacement and Disposal
Batteries included with Extreme products are encapsulated and must be replaced only by qualified Extreme Service personnel.
Contact your Extreme Networks Service personnel for product replacement. Do not attempt to replace the battery. If these instructions are disregarded and replacement of these batteries is attempted, the following guidelines must be followed to avoid danger of explosion:
- Replace with the same or equivalent battery type as recommended by the battery manufacturer.
- Dispose of the battery in accordance with the battery manufacturer‘s recommendation.
