Summit 350 W AC power supplies are available in the following models:
These power supplies are compatible with Summit X460-G2 switch models that have the same airflow direction as the power supply.
These power supplies have a keyed power inlet (C16) that requires a notched (C15) power cord.
The Summit 350 W AC power supplies have the status LEDs listed in Summit 350 W AC Power Supply LED Status Indications.
| IN_OK (Green) | OUT_OK (Green/RED) | Description |
| Off | Off | No AC input power connection or low AC voltage |
| On | Off | AC input good; output disabled |
| On | (Red) On | AC input good; output fault |
| On | (Green) On | AC input good; output good |
