Summit 770 W AC Power Supplies
Summit 770 W AC power supplies are available in the following models:
These power supplies are compatible with ExtremeSwitching X590, X690, and X870 switches that have the same airflow direction as the power supply.
The Summit 770 W AC power supplies have the status LEDs listed in Summit 770 W AC Power Supply LED Status Indications.
IN_OK (Green) OUT_OK (Green/RED) Description
Off Off No AC input power connection or low AC voltage
On Off AC input good; output disabled
On (Red) On AC input good; output fault
On (Green) On AC input good; output good
