The Extreme Networks EPS-500 External Power Supply Unit (Model 10911) provides additional power to compatible switches and other Extreme switches. You can use the EPS-500 power supply as a redundant power supply with the following Extreme Networks switches:
The EPS-500 power supply provides up to 500 W of total power and up to 375 W of power dedicated to PoE applications. When this power supply is used with one of the listed Summit switches, the internal and external power supplies are fully fault tolerant and load-sharing. If one power supply fails, the other power supply will provide sufficient power to operate the switch.
| Power LED | Meaning |
| Green, solid | The external power supply is operating normally. |
| Off | The external power supply is not connected. |
An AC power input cord is not provided; you can order an appropriate cord from Extreme Networks or from your local supplier. The power cord must meet the requirements listed in Power Cord Requirements for AC-Powered Switches and AC Power Supplies.Each EPS-500 power supply is shipped with a special redundant power supply cord.
