The EPS-160 External Power Module (Model 10907) is a modular power supply for use with the EPS-T chassis.
The EPS-T is a rack-mountable chassis or tray that holds one or two EPS-160 power supplies. Each EPS-160 power supply provides one-to-one redundancy for an attached Extreme Networks switch.
You can order the EPS-T chassis with one or two EPS-160 power supplies already installed. You can also order an additional power supply from your Extreme Networks reseller.
EPS-160 LED Indications
| Power LED | Meaning |
| Green, solid | The external power supply is operating normally. |
| Off | The external power supply is not connected. |
An AC power input cord is not provided; you can order an appropriate cord from Extreme Networks or from your local supplier. The power cord must meet the requirements listed in Power Cord Requirements for AC-Powered Switches and AC Power Supplies.
