Summit 1100 W AC power supplies are available in the following models:
Both power supplies are compatible with Summit X460-G2 switch models that have the same airflow direction as the power supply.
The Summit 1100 W AC PSU-FB power supply (Model 10941) is compatible with the Summit X450-G2 PoE switch models.
The Summit 1100 W AC power supplies have a keyed power inlet (C16) that requires a notched (C15) power cord.
The Summit 1100 W AC power supplies have the status LEDs listed in Summit 1100 W AC Power Supply LED Status Indications.
| IN_OK (Green) | OUT_OK (Green/RED) | Description |
| Off | Off | No AC input power connection or low AC voltage. |
| On | Off | AC input good, 54V output disabled. |
| On | (Red) On | AC input good, output (54V) fault. |
| On | (Green) On | AC input good, DC outputs in spec. |
