These power supplies are compatible with the following switch models:
The power supply must have the same airflow direction (front-to-back or back-to-front) as the switch with which it is being used. In a redundant power configuration, the airflow direction must be the same for both power supplies, and it must match the airflow direction of the fans in the switch.
The Summit 550 W power supplies (AC and DC) have the status LEDs listed in Summit 550 W Power Supply LED Status Indications.
| Position | Color and State | Meaning |
| Top Power Good |
Steady Green | +3.3VSB ok; 12 V ok; power supply is working properly. |
| Middle
Power Supply Fail |
Steady Amber | Fault condition (for example, 3.3VSB OCP/UCP, 12V OCP/UCP, or fan failure). |
| Bottom AC OK |
Steady Green | Power supply is connected to
power. If the cord is connected and this LED is off, the power supply is defective. |
