The Summit X450e-48p switch is powered by both an internal power supply and an optional external redundant power supply system.
For a detailed discussion of these concepts, see the Power over Ethernet section in the .The Summit X450e-48p switch can be powered by one, two, or three external power modules through the redundant power input connector on the rear of the switch.
The EPS-C (External Power Supply Chassis) is shipped with the redundant power supply cable that connects to the redundant input connector on the rear of the switch. The EPS-C chassis can hold from one to three 600-Watt EPS-600LS external power module units.
| Internal Power Supply Status | EPS-600LS (1x) | EPS-600LS (2x) | EPS-600LS (3x) | External Power Supply/Chassis Failed/Disconnected |
Internal Power Supply: Power On |
370 W of redundant power |
740 W of external power only Internal power supply disabled |
740 W of external power only with 2:1 redundancy Internal power supply disabled |
370 W of internal power only |
Internal Power Supply: Power Failure |
370 W of external power only |
740 W of external power only |
740 W of external power only with 2:1 redundancy |
No PoE power |
For more information, see EPS-600LS External Power Module.
