The following graphic and table show the available AP3020X ports and connectors.
| Item | Port | Description |
| 1 | Kensington security slot | A security feature that prevents someone from removing the AP. This is an optional task. |
| 2 | Reset button | Perform a reboot or factory reset. |
| 3 | Console port | Micro USB console port for a serial connection between your management system and the access point. Use the port when you troubleshoot the AP. Tip: The best practice is to use the Extreme Networks micro USB cable (ACC-WIFI-MICRO-USB). When you connect to the device, the management station must have a VT100 emulation program, such as the terminal emulator TeraTerm Pro or Hilgraeve HyperTerminal. Set your baud rate to 115200.
Caution: The console port can only be used with the Extreme Networks console cable. You could damage the AP if you use another cable.
| 4 | External antenna port | The AP3020X has two 2.4/5 GHz ports for external antennas. Not shown: The AP3020X also has two fixed, integral antennas (5/6 GHz). |
| 5 | 2.0 USB, Type A, 5V/1A with PoE 802.3at. | Used with a thumb drive or other external device. The USB port has a locking mechanism that prevents devices plugged into the port from being dislodged. |
| 6 | Ethernet port with cap. | Ethernet port with RJ45 connectors:
A standard Ethernet cable can be used if you want the cable visible. A flat cable and a cable cap are required if you want to hide the Ethernet cable. |
