Installation Workflow
An AP joins your network automatically when your network meets the DHCP and DNS prerequisites. But you can save time and configure the AP before you install it with the pre-provision mode. You can revert the AP to production mode when you are ready for deployment.
For more information on deployment, see the Knowledge Base article How to deploy a new Access Point or replace a faulty Access Point to your ExtremeCloud IQ Controller. AP deployment is also documented in ExtremeCloud IQ Controller documentation and the IQ Engine documentation.
Important
Important
Before you install your AP, read the deployment and onboarding information in ExtremeCloud IQ Controller Deployment Guide for on-premises deployments or the Extreme Platform ONE Networking User Guide for a Cloud deployment.
Extreme Networks devices, including access points, require firmware updates to ensure optimal performance and security. During deployment, upgrade your APs to the latest firmware.
Caution
Caution
Do not stack APs on top of each other during onboarding or configuration. This can cause heat to build up between the APs, damage the radomes, and void the warranty.
Confirm that Domain Name System (DNS), Network Time Protocol (NTP), and the firewall ports are configured and available before deployment. Create a firewall rule to allow outbound traffic from Extreme Networks devices. For more information about firewalls, see Firewall Configuration Guides.
As a best practice, configure the DHCP options on your DHCP server to assign an allowed NTP server to Extreme Networks devices. Both DNS and NTP are critical for country and region detection and certificate validation. For more information about DNS and NTP, see ExtremeCloud IQ Controller Deployment Guide for Cloud deployment and Extreme Campus Controller Deployment Guide for Campus or on-premises deployment.
Use the information in the following table to help you install your access point.
Table 1. Installation Workflow
StepsActionPurpose
1
Verify the box contents.
Confirm that your AP and accessories arrived complete and undamaged.
2Install the access point to one of the following:Install the AP on a ceiling or wall, and connect the network cable. If you use Power over Ethernet (PoE), the AP turns on.
The AP begins a discovery process to determine its own IP address and the IP address of the controller. When the discovery process is successful, the AP registers with the controller. For more information, see the following articles:
3(Optional) Lock the access point.Secure the AP and prevent someone from removing it.
4(Optional) Onboard the AP with the ExtremeCloud IQ Mobile Onboarding application.Scan the QR code or bar code on the back of the device and begin the onboarding process.
5Confirm that the LED is white. A white LED indicates that your AP has started and registered with the Cloud. An amber light indicates a technical issue that requires a resolution. For an explanation of the LED states, see LED Descriptions.
