You can clean your AP with the following solutions:
Hydrogen peroxide (a 3%
solution)
Chlorine bleach
Sodium hypochlorite (a 0.05%
solution)
Ethyl alcohol (a 75%
solution)
Isopropyl alcohol (a 75%
solution)
White vinegar
Sporicidal (peracetic acid; a
0.5% solution)
Water
Baking soda (a 3:1
solution)
Non-abrasive soap
Caution
Do not wash or immerse the AP in a liquid as you will damage the device and
void the warranty. Instead, wipe the plastic housing, also called the
radome, with a damp cloth avoiding the ports and connectors.
