Use the following information when you order your AP. Extreme Networks sells the AP3020/X with the AH-ACC-BKT-AX-TB mounting bracket.
| Part Number | Description |
AP3020-WW | Indoor Dual Radio Wi-Fi 7 AP, 2.4 GHz and 5 GHz or 5GHz and 6GHz OR Dual 5 GHz, Multi-rate Port, Internal antennas. IoT Radio, Includes AH-ACC-BKT-AX-TB mounting bracket. Domain: World SKU |
AP3020-WW-TAA | Indoor Dual Radio Wi-Fi 7 AP, 2.4 GHz and 5 GHz or 5GHz and 6GHz OR Dual 5 GHz, Multi-rate Port, Internal antennas. IoT Radio, Includes AH-ACC-BKT-AX-TB mounting bracket. Domain: World SKU TAA Compliant |
AP3020-EG | Indoor Dual Radio Wi-Fi 7 AP, 2.4 GHz and 5 GHz or 5GHz and 6GHz OR Dual 5 GHz, Multi-rate Port, Internal antennas. IoT Radio, Includes AH-ACC-BKT-AX-TB mounting bracket. Domain: Egypt |
| AP3020-IL | Indoor Dual Radio Wi-Fi 7 AP, 2.4 GHz and 5 GHz or 5GHz and 6GHz OR Dual 5 GHz, Multi-rate Port, Internal antennas. IoT Radio, Includes AH-ACC-BKT-AX-TB mounting bracket. Domain: Israel |
AP3020X-WW | Indoor Dual Radio Wi-Fi 7 (2x2:2): 2.4 GHz & 5 GHz or 5 GHz & 6 GHz, Dual 5 GHz, Dual IoT, Multi - rate Port, External antennas. Integral on 6 GHz. Includes (2) ML-2452-APA2-02 & AH-ACC-BKT-AX - TB mounting bracket. Domain: World SKU |
AP3020X-WW-TAA | Indoor Dual Radio Wi-Fi 7 (2x2:2): 2.4 GHz & 5 GHz or 5 GHz & 6 GHz, Dual 5 GHz, Dual IoT, Multi - rate Port, External antennas. Integral on 6 GHz. Includes (2) ML-2452-APA2-02 & AH-ACC-BKT-AX-TB mounting bracket. Domain: TAA Compliant |
AP3020X-IL | Indoor Dual Radio Wi-Fi 7 (2x2:2): 2.4 GHz & 5 GHz or 5 GHz & 6 GHz, Dual 5 GHz, Dual IoT, Multi - rate Port, External antennas. Integral on 6 GHz. Includes (2) ML-2452-APA2-02 & AH-ACC-BKT-AX - TB mounting bracket. Domain: Israel |
