This device complies with ISED's licence-exempt RSSs. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) This device must accept any interference received, including interference that may cause undesired operation.
RLAN devices operating in 5925-7125MHz subject to following -
Standard Power devices operating in 5925-7125MHz subject to following-
AP3020 Antenna Information
This product uses an integrated internal antenna, permanently installed and not user-replaceable.
AP3020X Antenna Information
This device uses both integrated internal and detachable external antenna. Antenna types, models, and gain information can be found in product documentation. Installer and operator must only use manufacturer approved antenna listed in the product documentation to comply with elevation mask requirements.Tested Antennas
ML-2452-APA2-02 (WNC): Dipole Omni, reverse SMA, 2.4 GHz: 2.71 and 5 GHz: 4.46dBi
AIO-DD75060-RPSMA (Extreme Networks): Panel, sector 60°, reverse SMA, 2.4 GHz: 7.17dBi and 5 GHz: 7dBi
AIO-DD05120-RPSMA (Extreme Networks): Dual-Polarized Panel, sector 120°, reverse SMA, 2.4 GHz: 5.17dBi and 5 GHz: 4.5dBi
AIO-DD15020-RPSMA (Extreme Networks): MIMO directional panel, reverse SMA, 2.4 GHz: 11.67dBi and 5 GHz: 14.5dBi
Radiation Exposure Statement
This equipment complies with IC RSS-102 radiation exposure limits set forth for an uncontrolled environment. This equipment should be installed and operated with minimum distance 40 cm between the radiator & your body.
Cet équipement est conforme aux limites d'exposition aux rayonnements IC établies pour un environnement non contrôlé. Cet équipement doit être installé et utilisé avec un minimum de 40 cm de distance entre la source de rayonnement et votre corps.
