Box Contents
Your Extreme Networks access point ships with everything that you need for a basic installation. You purchase all optional brackets and accessories separately.
Confirm that you have received the following items before you install your device.
Table 1. Hardware
QuantityItem
1AP3020/X Extreme Networks access point
1Regulatory document for your access point
1
AH-ACC-BKT-AX-TB mounting bracket
2 Phillips pan-head wood screws
2Phillips head plastic screw-in anchors
2ML-2452-APA2-02 antennas
1Ethernet port cap.
Keep this item. You cannot order a replacement.
