The following table shows the additional accessories available for your access point.
For more information, see the Wi-Fi6 11ax Accessories Installation Guide.
| Part Number | Description |
ACC-WIFI-MICRO-USB |
Extreme Networks micro USB cable.
Caution: The console port can only be used with the Extreme Networks console cable. You could damage the AP if you use another cable.
Note: When you connect to the micro-USB console port, the management
station from which you connect to the device must have a VT100 emulation program,
such as TeraTerm Pro (a free terminal emulator) or Hilgraeve HyperTerminal (provided
with Windows operating systems from XP forward).
