| Item | Description |
| AH-ACC-BKT-AX-TB |
Mounting bracket that can be used to mount the access point on flat surfaces such as Prelude ceilings (15/16 in. ceiling grid), Suprafine ceilings (flat bottomed 9/16 in. ceiling grid), and walls. Note: AH-ACC-BKT-AX-TB is included with the access point.
AH-ACC-BKT-AX-IL |
Mounting bracket for Interlude ceilings (9/16 in. wide T-bar with center protrusion and has less than 1/4 inch between the wall and the access point). |
AH-ACC-BKT-AX-SL |
Mounting bracket for Silhouette ceilings (ceiling grid with 1/8 in. or 1/4 in. bottom opening). |
AH-ACC-BKT-AX-WL |
Mounting bracket for direct-to-wall installations when a 1.25 in. of space is desired between the wall and the access point. |
| ACC-BKT-TB-NF | Mounting bracket for 15/16 in. wide T-bars with sculpted ceiling tiles. |
| AH-ACC-BKT-916-KIT | Mounting bracket for 9/16 in. wide T-bars with sculpted ceiling tiles. |
| ACC-BKT-AX-BEAM |
Mounting bracket for beam mounting. |
ACC-BKT-AX-JB |
Mounting bracket for junction box or wall mounting. |
| ACC-BKT-AX-WNGADAPT | Adapter bracket for Cloud AP to WiNG Mounting Plate (#37201). Ships in a pack of 10. |
| ACC-BKT-AX-TBW | Mounting bracket for 1.5 in wide extruded T-Bars with flat ceiling tiles. |
