The AP3020X has two integral antennas which cannot be removed. An integral antenna is fixed to the AP and cannot be disconnected. It is also called a fixed antenna or integrated antenna.
The AP3020X also supports two RP-SMA antennas which you can attach to the AP and use to extend your coverage. You can use any of the supported antennas listed in the Antennas section.
External antennas extend coverage for the AP3020X. For information on connecting antenna leads to the correct port, read Antenna Connectors.
Thread the antennas onto the RP-SMA connector.
Tighten each antenna to a torque of 0.56 N-m (5 in-lb).
Twist all antennas so the bend opening is toward the radome.
Rotate each antenna to the 45-degree or 90-degree position for maximum signal strength.
