Preinstallation Tasks
Complete the following tasks before installation to simplify deployment.
Important
Important
Before you install your AP, read the deployment and onboarding information in ExtremeCloud IQ Controller Deployment Guide for on-premises deployments or the Extreme Platform ONE Networking User Guide for a Cloud deployment.
Extreme Networks devices, including access points, require firmware updates to ensure optimal performance and security. During deployment, upgrade your APs to the latest firmware.
Site Survey
Before you install your AP, do a site survey and coverage map so that you can identify and address potential issues.
Answer the following questions before you install the AP:
  • What is the the purpose of the WLAN?
  • Which applications do users run over the WLAN?
  • Who will use the WLAN?
  • What devices will be connecting to the WLAN?
  • Are there any mounting or aesthetic restrictions?
Consider the following items as you plan your deployment:
  • Capacity and coverage requirements
  • Existing issues such as coverage gaps
  • Existing networks or devices that can interfere with your network
  • Interference from floors above and below, or from outside sources such as nearby office buildings
For more information on site surveys, see the Knowledge Base article What is Wireless Site Survey and why is it important?.
Verify Network and Power Requirements
Perform the following tasks:
  • If you plan to use Power over Ethernet (PoE), confirm that it meets requirements of the AP. See Power Profiles.
  • Document the switch and ports used by the AP with LLDP protocol.
  • Confirm cables meet or exceed the required specifications.
  • Check that the AP power turns on correctly.
