UK Statement and CE Statement
This equipment complies with the UK and EEA radiation exposure limits set forth for an uncontrolled environment. This equipment should be installed and operated with minimum distance of 20cm between the radiator and your body.
The frequency and the maximum transmitted power in the UK and European Conformity are listed in the following table:
Table 1. AP3020 Frequencies and Transmitted Power
CEUK
2402-2480MHz (BT): 9.87 dBm2402-2480MHz (BT): 9.87 dBm
2405-2480 MHz(802.15.4): 6.47 dBm2405-2480 MHz(802.15.4): 6.47 dBm
2412-2472 MHz: 19.98 dBm 2412-2472 MHz: 19.98 dBm
5180-5240 MHz: 22.97 dBm 5180-5240 MHz: 22.97 dBm
5260-5320 MHz: 22.97 dBm5260-5320 MHz: 22.97 dBm
5500-5700 MHz: 29.97 dBm 5500-5700 MHz: 29.97 dBm
5745-5825 MHz: 13.95 dBm 5745-5825 MHz: 22.97 dBm
5955-6415 MHz: 22.98 dBm 5955-6415 MHz: 22.98 dBm
Table 2. AP3020X Frequencies and Transmitted Power
CEUK
2408-2480MHz (BT): 9.96 dBm 2408-2480MHz (BT): 9.96 dBm
2405-2480 MHZ(802.15.4): 7.64 dBm 2405-2480 MHZ(802.15.4): 7.64 dBm
5260-5320 MHz: 29.98 dBm 5260-5320 MHz: 29.98 dBm
5500-5700 MHz: 29.96 dBm 5500-5700 MHz: 29.96 dBm
5745-5825 MHz: 13.97 dBm 5745-5825 MHz: 22.97 dBm
5955-6415 MHz: 22.97 dBm 5955-6415 MHz: 22.97 dBm
CE - The device is restricted to indoor use only when operating in the 5945 to 6425 MHz frequency range.
UK - The device is restricted to indoor use only when operating in the 5945 to 6425 MHz frequency range.
Hereby, Extreme Networks declares that the radio equipment AP3020/X is in compliance with Radio Equipment Regulations 2017.
Operation on oil platforms, cars, trains, boats, and aircraft shall be prohibited except for on large aircraft flying above 10,000 ft.
For full text of the UK Declaration of Conformity, please contact Extreme Networks Regulatory Compliance at compliancerequest@extremenetworks.com.
Warning
Warning
CE Co-location MPE Statement: This equipment complies with CE radiation exposure limits set forth for an uncontrolled environment. This equipment should be installed and operated with minimum distance of 20 cm between the radiator and your body.
The device is restricted to indoor use only when operating in the 5150 to 5350 MHz frequency range.
Table 3. Selling Countries:
ATBEBGHRCYCZDK
EEFIFRDEELHUIE
ITLVLTLUMTNLPL
PTROSKSIESSEUK (NI)
Warning
Warning
This is a class B product. In a domestic environment, this product may cause radio interference in which case the user may be required to take adequate measures.
