The LED status light shows the operating status of the AP. A solid white means that the AP is working correctly. A solid or blinking amber indicates an issue.
The following tables show the LED states based on your firmware platform.
| Status | Activity |
| Dark | Power is off. |
| Solid white | The device power is on and the AP is ready to use. The device has successfully established a Control and Provisioning of Wireless Access Points (CAPWAP) connection to ExtremeCloud IQ and is operating correctly. |
| Solid amber | The power is on and the AP is in starting up, or is running without a CAPWAP connection. |
| Fast-blinking amber | The IQ Engine firmware is updating. |
| Status | Activity |
Dark |
Power is off or the AP is taken over by the controller. Configuration pushes down to AP from controller to turn off the LED. |
Solid white |
The AP is starting up or is already taken over by the controller. |
Flashing fading white |
The flashing white LED helps you locate the AP. |
Solid amber |
A firmware upgrade is occurring |
The AP is acquiring the DHCP IP. |
