Technical Specifications
The AP3020/X supports both 802.3at PoE and 802.3af PoE.
802.3at PoE is required for 5W USB.
For more information about the technical specifications, see the AP3020/X data sheets found here.
Important
Important
South Korea, Mexico, Taiwan, and Brazil require the use of CAT6 shielded cable.
