You must be a system administrator to add a network interface.Take the following steps:
| Field | Description |
| Name | Name of the interface. |
| Mode | Physical - The topology is the native topology of a data plane and it represents the actual Ethernet ports. |
| VLAN ID | ID for the virtual network. |
| Tagged | Indicates if the interface tags traffic. When traffic is tagged, the VLAN ID is inserted into the packet header to identify which VLAN the packet belongs to. Tagging can identify the port or interface to send a broadcast message to. |
| Port | Physical port on the ExtremeCloud IQ Controller for the interface. |
| Enable Device Registration | Enable or disable AP registration through this interface. When enabled, wireless APs use this port for discovery and registration. Other ExtremeCloud IQ Controllers can use this port to enable inter-ExtremeCloud IQ Controller device mobility if this port is configured to use SLP or the ExtremeCloud IQ Controller is running as a manager and SLP is the discovery protocol used by the agents. |
| Management Traffic | Enable or disable Management Traffic through this interface. Enabling management provides access to SNMP (v1/v2c, v3), SSH, and HTTPs management interfaces. |
| MTU | Maximum Transmission Unit (MTU). Standard is 1500 bytes. Fixed value. |
| Layer 3 | |
| IP Address | For an Admin topology, the Layer 3 check box is selected automatically. The IP address is mandatory for a Physical topology. This allows for IP Interface and subnet configuration together with other networking services. |
| CIDR | CIDR field is used along with IP address field to find the IP address range. |
| FQDN | Fully-Qualified Domain Name |
| DHCP | Dynamic Host Configuration Protocol allows network
        administrators to centrally manage and automate the assignment of IP addresses on the
        corporate network. DHCP sends a new IP address when a computer is plugged into a different
        place in the network. The protocol supports static or dynamic IP addresses and can
        dynamically reconfigure networks in which there are more computers than there are available
        IP addresses. Valid values are:
