To create a AAA network associated to a Pass-thru External RADIUS Accept Policy. Take the
        following steps:
On ExtremeCloud IQ
                    Controller :
                Use the IP address of the Access Control Engine—that is, the Network Access Control (NAC) server—as the primary RADIUS server.
            - Configure a RADIUS server for AAA authentication.
                    - Log in to ExtremeCloud IQ
                    Controller and go to  and add a new RADIUS server.
 - Configure the following parameters:
- Radius Server IP Address
 - Add the Access Control Engine IP address.
 - Shared Secret
 - Provide the Access Control Engine Shared Secret.
To find the Shared Secret of the Access Control Engine, log in to ExtremeCloud IQ Site Engine and go to:
                  - Create a new network.
- Auth Type
 - WPA2 Enterprise w/ RADIUS
 - Authentication Method
 - RADIUS
 - Primary RADIUS
 - IP Address of the External NAC added in Step 1.
 - Default Auth Role
 - Select a role other than Enterprise User.
 - Default VLAN
 - Select a Default VLAN. B@AP VLAN ID
Both B@AP and B@AC are supported for NAC.
 - Select Save.
 - Create a policy rule.
Go to  and configure the following parameters:
- Location Group
 - Network: <name of your network>
 - Accept Policy
- To configure a Default Auth Role Policy, select Use Default Auth Role.
 - To configure a Pass-Through External RADIUS Accept Policy, select Pass Through External RADIUS. See Configure a Pass Through Rule for further instructions.
 - Select Save.
On ExtremeCloud IQ Site Engine:
            - Go to
 - Edit the rule you created on ExtremeCloud IQ
                    Controller here.
 - 802.1x
 - End-System Group
 - Any
 - Select Save and enforce the Access Control Engine.
On ExtremeCloud IQ
                    Controller:
            - Assign the network created previously and its Default Auth Role to a site and save.
                    - Go to  and select a site.
 - Select the Device Groups tab and select a device group.
 - Beside the Profile field, select
 to edit the device group profile. - Go to the Networks tab and select the configured network.
 - Go to the Roles tab and select the configured Default Auth Role.
Associate clients to the SSID of the Network, when prompted for the username and
      password, use the username and password created with the New User. The external NAC server matches the rule you created under New Rule and upon successful authentication sends an Access-Accept and a
      Filter-ID Enterprise User. The ExtremeCloud IQ
     Controller Access Control engine applies the Enterprise User Role instead of the
      Default Auth Role that was configured under Network Settings.
The
Enterprise User role must exist on
ExtremeCloud IQ
     Controller and must be
        assigned to the same device group as the client in order to be applied.
