- Peer Discovery (RFC 7585) Enabled
 - Select
                            this option to enable peer discovery.
Peer Discovery uses the Network
                                Access Identifier (NAI) in the UserName attribute of the RADIUS
                                packet to dynamically discover the RADIUS server using DNS.
It
                                is supported for Secure(TLS) servers only; therefore, Peer Discovery
                                defaults to the Type
                                value = Secure. Both the server IP address and port values are
                                dynamically discovered. The port is usually TCP 2083.
 - Type
 - Select between Standard
                            (UDP) or Secure (RADSEC) protocol.
RADSEC supports RADIUS
                                transactions conducted securely over TCP and TLS (RFC 6614). RADSEC
                                is not supported with Local Onboarding, and it is not available with
                                ADMIN access.
 - Server Address
 - The
                            RADIUS server address. This value cannot be changed.
 - Port
- A User Datagram Protocol (UDP) port number used for client
        authentication. UDP needs only one port for full-duplex, bidirectional traffic. Select a
                                    UDP port number for standard protocol security.
 - For a secure
                                    RADSEC protocol, use port 2083 This is the default port.
                         - Trust Point
 - Refers to the certificate
                            file required for the secure RADSEC protocol. When a secure RADSEC
                            protocol is configured, the certificate file of the Access Network
                            Provider (ANP) and its private key must be specified, and the CA must
                            also be specified to authenticate the peer's certificate. Select from
                            the list of configured Trust Points. For information about configuring
                            Trust Points,
                            see Trust Points
                                in the ExtremeCloud IQ Controller User Guide.
 - Retries
 - Determines the number of times ExtremeCloud IQ
     Controller will
        attempt to authenticate an end user.
For Local
                                Onboarding, use the Retries and Timeout values with the RADIUS Server
                                    Health Check parameters to detect RADIUS servers
                                that are not responding and fail over to a second server if
                                necessary. When Local Onboarding bypassed is enabled, all RADIUS
                                requests are sent to one RADIUS server until it fails; then, the
                                next RADIUS server is used.
 - Timeout
 - Determines a timeout value, in seconds, for the RADIUS server
        connection.
 - Status Server Request Timeout
 - Status Requests are sent
                            by the RADIUS client to query the status of the RADIUS server. The
                            Status Request Timeout is the period between two successive status
                            requests . Status requests are only sent when the RADIUS server has
                            stopped responding to the Access Request with an Access Response.
 - Shared Secret
 - The password that is used to
        validate the connection between the client and the RADIUS server.
For RADSEC,
                                    radsec is the default password.
 - Mask
 - Determines if the Shared Secret or password value is displayed on the user
        interface. Enable Mask to display dots in place of the Shared Secret or password value. To
        display the password characters, clear the Mask check box.
