Use this procedure to create the MBA network associated to a Pass-thru External RADIUS accept policy.
- Configure a RADIUS server for AAA authentication.
                    - Log in to ExtremeCloud IQ
     Controller and go to  and add a new RADIUS server.
 - Configure the following parameters:
- Radius Server IP Address
 - Add the Access Control Engine (NAC server) IP address.
 - Shared Secret
 - Provide the Access Control Engine Shared Secret.
To find the Shared Secret of the Access Control Engine, log in to ExtremeCloud IQ Site Engine and go to:
                  - Create a new network.
                    - Enable MAC-based authentication (MBA) and choose an appropriate MBA Timeout Role.
 - Clear the Authenticate Locally for MAC check box.
 - Choose RADIUS as the Authentication Method and select the Access Control Engine added in Step 1 as the Primary RADIUS.
 - Select a Default VLAN.
 - Click Save.
                  - Add a new rule.
                    - From ExtremeCloud IQ
     Controller, navigate to .
 - Click Add.
 - In the Location Group drop-down menu, select Network: <name of your network>.
 - From the Accept Policy field:
- To configure a Default Auth Role Policy: select Use Default Auth Role.
 - To configure a Pass-thru External RADIUS Accept Policy: select Pass Through External RADIUS.
 - Save the rule.
                  - Assign the network created previously and its Default Auth Role to a site and save. Take the following steps:
                    - Go to  and select a site.
 - Click the Device Groups tab and select a device group.
 - Beside the Profile field, click
 to edit the device group profile. - Go to the Networks tab and select the configured network.
 - Go to the Roles tab and select the configured Default Auth Role.
Finally, associate clients to the SSID of the network. The Access-Request is sent to
      the ExtremeCloud IQ Site Engine Access Control Engine. The Access Control Engine matches the MAC address of the user with one of the
      MAC addresses in the End-System Group (that was created earlier) and sends an Access-Accept
      with a Filter-ID Enterprise User. The ExtremeCloud IQ
     Controller applies the
        Enterprise User Role instead of the Default Auth Role that was configured under
      Network Settings.
The
Enterprise User role must exist on
ExtremeCloud IQ
     Controller and must be assigned to the same device group as the client
        in order to be applied.
