This section describes the procedure to configure Linux DNS server for ExtremeCloud IQ Controller IP addresses discovery.
subnet 10.2.221.0 netmask 255.255.255.0 {
range 10.2.221.30 10.2.221.130;
option slp-directory-agent true 10.2.221.2;
option subnet-mask 255.255.255.0;
option domain-name-servers 192.168.6.2;
option domain-name "Availability-221.com";
option routers 10.2.221.1;
default-lease-time 40000;
                Create a file for the domain name configured in dhcp.conf (in this example, "Availability-221.com") as follows at /var/named/chroot/var/named.
The name of the file should be the following: /var/named/chroot/var/named/named.Availability-221.com
$TTL 86400
@     IN    SOA   ns1.availability-221.com.     hostmaster.availability-221.com.    (
                            2      ; serial #
                            28800   ; refresh
                            14400   ; retry
                            3600000 ; expire
                            86400   ; ttl
                IN    NS    ns1.availability-221.com.
Controller      IN    A     10.2.221.2
// a caching only nameserver config
options {
 * If there is a firewall between you and nameservers you want
 * to talk to, you might need to uncomment the query-source
 * directive below.  Previous versions of BIND always asked
 * questions using port 53, but BIND 8.1 uses an unprivileged
 * port by default.
// query-source address * port 53;
version "Bind";
recursion no;
directory "/var/named";
zone "Availability-221.com" {
       type master;
       file "named.Availability-221.com";
zone "0.0.127.in-addr.arpa" {
type master;
file "named.local";
allow-update { none; };
                ps -ef | grep named named 10023 1 0 Feb18 ? 00:00:00 /usr/sbin/named -u named -t /var/named/chroot root 7687 7531 0 22:14 pts/982 00:00:00 grep named
nslookup Controller.Availability-221.com Server: 127.0.0.1 Address: 127.0.0.1#53 Name: Controller.Availability-221.com Address: 10.2.221.2
