ExtremeCloud IQ Controller v10.15.01 Deployment Guide
Configuring DHCP, NPS, and DNS Services
NPS Service Configuration
Add a New Network Policy
> Create Condition: Client IPv4 Addresses
Extreme Networks, Inc. September 10, 2025
Abstract
Preface
AP Regulatory Information
New in this Guide
Release 10.15.01
New Features
Updates
Deploy ExtremeCloud IQ Controller
VE6120K, VE6125K Virtual Appliances
VE6120H Virtual Appliance
VE6120,VE6125 Virtual Appliance
CE1000, CE2000, and CE3000 Container Applications
Appliance and Container Application Specifications
Discovery and Registration
Discovery Process for APs and Adapters in a Centralized Site
Discovering Centralized Site APs and Adapters
Switch Discovery Process
Discovering Switches
Switch Discovery in an Availability Pair
Sites
Device Groups
DHCP Service Configuration
Configuring DHCP on Windows Server 2012 R2
Add a New DHCP Scope
Create New DHCP Options
Creating Option 78
Configure DHCP Server Options
Configuring Vendor Class on Windows Server 2012 R2
Configuring Option 43
Configuring Server Options
Configuring DHCP on a Red Hat Linux Server
Configuring DHCP Option 43 on a Linux Server
Configuring the ExtremeCloud IQ Controller as an NPS Client
Create Condition: Windows Groups
DNS Service Configuration
Configuring DNS for Wireless AP Discovery
Configuring DNS on a Linux Server
Configure ExtremeCloud IQ Controller for Local DHCP Management
Add a Physical Interface
Local DHCP Settings
Centralized Site with an Internal Captive Portal
Adding a Centralized Site with Device Group
Configuring an Internal Captive Portal
Specifying B@AC Network Topology
Configuring a Captive Portal Network
Working with Internal Captive Portal Engine Rules
Editing Device Group Profile for Network and Role
Creating Adoption Rules
Centralized Site with a AAA Network
Configuring a AAA Network
Creating an Engine Rule
Creating a Policy Role
Applying a AAA Network and Role to the Device Group
Mesh Point Network Configuration
Mesh Point Network Settings
Configure Device Groups for Mesh Point
Advanced Configuration Profile and Mesh Device Settings
Configure Transparent Bridge
Configuring an ExtremeControl Access Control Engine (NAC Server) for MBA and AAA Authentication
Configuring the Access Control Engine
Network with Default Auth Role
Configuring an MBA Network
Network with Pass-Through External RADIUS
Configure a Pass Through Rule
Configure User Authentication
External Captive Portal on a Third-Party Server
Firewall Friendly External Captive Portal Flow of Events
FF-ECP on ExtremeCloud IQ Controller
Configure the Firewall
Configure an External Captive Portal
Understand Processing Performed by the ECP
The Redirection URL Sent from ExtremeCloud IQ Controller
Verify the Signed Request
Compose the Login or Splash Screen Page
Approve the Client
Signing the Redirection to ExtremeCloud IQ Controller
Case 1: When a RADIUS Server Authenticates the Client
Case 2: When the ECP is the Final Authority
Access Control Rules for Admin Portal Access
Configure Access Control Group
Default Access Control Groups
Configure Admin Access Policy Role
Configure Access Control Rule
Default Access Control Rules
Define Rule Precedence
Centralized Web Authorization
CWA with ISE Deployment
AAA Policy Network Configuration — ISE
AAA Policy Settings for CWA
RADIUS Settings
CWA Network Settings — ISE
CWA Policy Redirection Role — ISE
CWA Server Configuration — ISE
Configure Authorization Policy on Cisco?? ISE Server
CWA with ExtremeControl Deployment
Configure AAA Policy — ExtremeControl
CWA Network Settings — ExtremeControl
CWA Policy Redirection Role — ExtremeControl
CWA Server Configuration — ExtremeControl
Configure CWA on ExtremeControl
NAI Routing and Dynamic Discovery
AAA Policy Settings for NAI Routing
Configure a Regular Expression Realm
Deploying ExtremeCloud IQ Site Engine as an External Captive Portal
Configuring an External Captive Portal Network
Editing the Configuration Profile for Network and Roles
ExtremeCloud IQ Controller Default Pass-Through Rule
Adding ExtremeCloud IQ Controller as a Switch to ExtremeCloud IQ - Site Engine
Editing the Unregistered Policy on ExtremeCloud IQ - Site Engine
Editing the ExtremeCloud IQ - Site Engine Profile for Policy and Location-Based Services
Deploying an ExtremeGuest External Captive Portal
Configure an ExtremeGuest Server
Configure an ExtremeGuest Captive Portal Network
Configuration Settings on ExtremeGuest
Deploying Client Bridge
AP Client Bridge
Configure Client Bridge
Deploying an Availability Pair
Replace a Controller in an Availability Pair
Deploying an Availability Pair with Extreme AirDefense
Deployment Procedure
Configuring the Centralized Site with an AP3915 Profile
Configuring AirDefense
Deploying an Availability Pair and External Captive Portal
Configuring External Captive Portal Network
Editing the Device Group Profile for ECP Network
Integration with ExtremeCloud IQ
Deploy Universal APs
Onboarding Universal APs — ExtremeCloud IQ
Enhanced Discovery
Local Onboarding — Manual Entry
Local Onboarding— Import CSV file
Onboard a Controller to ExtremeCloud IQ
Access the Controller UI from ExtremeCloud IQ
PHP External Captive Portal, Controller‘s Firewall Friendly API
net-auth.php
login.php
common_utilities.php
crypt_aws_s4.php
ffecp-config.php
Select
Add
to add a condition.
Scroll down to Radius Client Properties and select
Enter the IP Address of the
and select
OK
Select
On the
Specify Access Permission
screen, select
Access granted
and select
On the
Configure Authentication Methods
screen, select
Add
and select
Microsoft: Smart Card or other certificate
. Then, select
OK
Add EAP
Select
Configure the Idle Timeout and select
Configure the Radius Attributes and select
Select
Finish
