| Field | Description |
| Network Name | Enter a unique, user-friendly value that makes sense for your business. Example: Staff |
| SSID | Enter a character string to identify the wireless network. Maximum 32 characters. Upper and lowercase allowed. Example: PermanentStaff |
| Status | Enable or disable the network service. Disabling the network service shuts off the service but does not delete it. |
| Auth Type | Define the
                    authorization type. Valid values are:
 For more information, see the ExtremeCloud IQ Controller User Guide or Online Help.  |
| Enable Captive Portal | Check this option to enable captive portal support on the network service. |
| Captive Portal Type | Select External as the Captive Portal Type. |
| ECP URL | URL address for the external captive portal. |
| Walled Garden Rules | Select Walled Garden Rules to configure policy rules for the external captive portal. |
| Identity | Determines the name common to both the ExtremeCloud IQ Controller and the external Web server if you want to encrypt the information passed between the ExtremeCloud IQ Controller and the external Web server. Required for signing the redirected URL. If you do not configure the Identity, the redirector on the AP drops the traffic. |
| Shared Secret | The password that is used to validate the connection between the client and the RADIUS server. |
| Use HTTPS for connection | Indicates that the connection will be secure with HTTPS. |
| Send Successful Login To | Indicates destination of
                    authenticated user. Valid values are:
| MAC-based authentication (MBA) | Check this option to enable MBA. |
Next, edit the configuration profiles in each device group, specifying the External Captive Portal network.
