To configure a mesh point network, do the following:
- Go to .
 - Configure the following
                            parameters:
- Mesh Point Name
 - Name that
                                    identifies the mesh point.
 - Mesh ID
 - Identifies the
                                    mesh network. APs must have the same Mesh ID in order to form
                                    mesh links. APs with configured mesh points exchange beacons and
                                    the Mesh ID is checked. If a Mesh ID does not match that of the
                                    network, the beacon is dropped. If the Mesh ID does match that
                                    of the network, the AP adds an entry in the Mesh Point Neighbor
                                        Table.
The SSID is used as the Mesh ID for networks that
                                        support AP39xx access points.
 - Auth Type
 A pre-shared key (PSK) is used to AES encrypt traffic
                                        traveling between Mesh Point APs. Modifying the key after a
                                        non-root AP is deployed may cause it to become stranded.
                                        Connect the non-root AP through the Ethernet port before
                                        changing the PSK.
 Select Edit
                                        Privacy to enter the WPA2 key.
