Configure a Policy Role that allows Admin access to the captive portal Admin page using Port 8445. Role Parameter Settings describes each setting and provides an example value configured for the Captive Portal Admin Role.
| Field | Description |
| Name | Name of the Policy Role. Example: Captive Portal Admin |
| Bandwidth Limit | Select this option to allow unlimited bandwidth. Select  |
| Default Action | Determines the access control default action. If you do not
                                        define policy rules for a role, the role's default action is
                                        applied to all traffic subject to that role. Policy Rules
                                        affect traffic that meets the filter criteria.  Example: For Role Captive Portal Admin the Default Action is Deny. Deny packets that do not match a filter rule or deny packets when a filter rule does not exist. When a packet does match the filter rule action Allow packet using the specified VLAN GTAC (222).  |
| VLAN ID | Policy roles default to the VLAN specified during network
                                        configuration. You can specify a unique VLAN here. Select
                                             Example: GTAC (222)  |
| Associated Profile | Indicates profiles that this role is associated with. In our example, Role is not associated with a Profile. |
| Rules | Specify the following L3 L4
                                            Rule: Example: Allow traffic from IP/Subnet 22.222.2./32 through Port 8445.  |
