From the Setting Up Your
                    Local Network dialog, you can import devices using a csv file:
                If you have not already done so,
                    create the CSV file. See below for an example of a CSV file.
                Select Import from CSV.
                Select Choose to
                    navigate to the CSV file. Or, drag the file onto the dialog.
                Select Onboard
                    Devices.
                Select Finish.
            Enhanced
                    Discovery — To take advantage of Enhanced Discovery while importing
                devices through CSV, formulate a multiple-column CSV file. For example:
Table 1. Example CSV file for
                        Enhanced Discovery support
                                | Serial Number |
                                Primary Controller IP Address |
                                Secondary Controller IP Address |
                                Host Name |
                                | xxxxxxxxx-10004 |
                                10.xx.xxx.4 |
                                10.xx.xxx.5 |
                                | xxxxxxxxx-28887 |
                                10.xx.xxx.9 |
                                10.xx.xxx.6 |
Host Name will be supported in a
                    future release of
ExtremeCloud IQ.
