From the Setting Up Your Local Network dialog, you can enter
                device serial numbers manually:
                Select Enter
                        Manually. Then, enter up to 10 device serial numbers separated
                    by commas. The devices must all be the same model number.
                Select the Device OS. For
                    example, WiNG.
                Optionally, select Enhanced
                        Discovery.
                    Select this option to define up to two specific controller IP addresses that
                        the selected APs will register with for local service. Provide the IP
                        address for the controllers. You have the option of defining a primary and
                        secondary controller.
Enhanced
                            Discovery is supported on AP3000. It requires ExtremeCloud
                        IQ version 23.6.1 or greater.
                Select Onboard
                    Devices.
                Select Finish.
        The APs display on the ExtremeCloud IQ Device List with the status Onboarded. New APs
            display the generic HOSTNAME
            because they are not yet registered with ExtremeCloud IQ. The AP Hostname automatically updates after the AP is powered on and
            connected into ExtremeCloud IQ.
