Create Vendor Class
To create a vendor class using the Windows Server 2012 R2 DHCP, IPv4 server utility:
- Go to Start > Administrative Tool > DHCP.
 - In the DHCP Server Utility,
                        right-click the DHCP server icon and select Define Vendor
                            Classes.You will create a new vendor class to program the DHCP server to recognize the VCI ExtremeWireless <AP model name>.
Define Vendor Classes
The DHCP Vendor Classes window displays.
DHCP Vendor Classes
 -  To create the new class,
                        select Add.The New Class dialog displays.
 - Provide a Display Name and Description for the vendor class.
 - Select the ASCII field and
                        type the VCI for the specific AP. For example, type AP410 for an
                        AP410i.The ID and Binary values are populated.
VCI AP410
 - Select OK. The new class is created.
Vendor Classes
 - Select Close.
