ExtremeCloud IQ Controller provides the availability feature to maintain service availability in the event of an outage. The Availability feature allows both AP and Client statistics to be available on both sides of the high-availability configuration.
Before you begin:
The Peer IP address must refer to a physical topology of the peer appliance. It can be the IP address of a physical port or the IP address of a Lagged interface. Configuring availability against a service topology such as the IP address (L3) of a Bridged@Controller appliance is not supported.In either configuration, however, most parameters can be configured on either appliance in the availability pair.
Use the spinner to set the Maximum Transmission Unit (MTU) to avoid data packet fragmentation. Set a value in the range 600–1800 bytes. The default value is 1500 bytes.
When MTU is 1800, ensure that Jumbo Frames is enabled on the Switch.
Important
Ensure that Secure Tunnel and MTU settings are identical on both primary and secondary controllers to prevent an issue in the event the link is lost before synchronization completes.Use the spinner to set the Maximum Transmission Unit (MTU) to avoid data packet fragmentation. Set a value in the range 600–1800 bytes. The default value is 1500 bytes.
Important
Ensure that Secure Tunnel and MTU settings are identical on both primary and secondary controllers.
It will take a few minutes for the two ExtremeCloud IQ Controller configurations to synchronize.From the Administration > System > Availability page, check the Availability Link Status and Synchronization Status indicators.
Go to Admin > Logs and look for the message Availability Link established with Peer <ip address>.
To verify synchronization, choose from the following actions:
View the Network Health widget from the Diagnostics dashboard. Go to Tools > Diagnostics > Dashboard.
Add a network health widget to the Overview dashboard:
Go to Dashboard
Select
to edit the dashboard.
Select Widgets.
Select System and drag Network Health onto the dashboard.
Section contents:
