Third-party applications
  • Packet capture applications
  • RESTful support to access SLX-OS
  • perfSONAR
  • ARPsponge
Third-party packages
  • Packages installed by default on the TPVM
  • RESTful application: Chrome browser – GUI RESTful access
  • RESTful application: cURL – Command line RESTful access
  • Tcpdump: Command line packet-capture utility
  • Tshark: Command line packet-capture utility
  • Wireshark: GUI packet-capture utility
  • Datadog or Splunk – External analytics software service
Extreme SLX-OS provides support for built-in applications (third-party packages shipped with the SLX-OS) that are listed in the Extreme SLX-OS Management Configuration Guide.
Hardware
The TPVM has 4 GB of RAM and 240GB of solid-state disk (SSD) memory, which limits the amount of data captured through packet capture applications. To overcome this limitation, Extreme provides support for the Network File System (NFS) mount of an external drive.
