LFS is not supported in 1G mode.When the device detects a local fault, it returns a remote fault to the link partner. When the device detects a remote fault, it returns an idle state.
The link is declared as DOWN and the port should display Protocol Down on the SLX-OS CLI.
The physical link is not bought down in both of the previous cases. The peer side based on its implementation might display that the link is UP when the Extreme device displays that the link is DOWN due to a fault detection.
The transmit (TX) packets, if any, are dropped at the MAC layer. The receive (RX) packets, if any, are dropped in the software.
The detected signal is reported as a RASTRACE message on the line card. The same information is reported on the MM as a RASLOG. The same behavior occurs when the signal is cleared.
