  1. Enter global configuration mode.
    device# configure terminal
  2. Enter interface configuration mode for port-channel 1.
    device(config)# interface port-channel 1
  3. Specify the option for strict priority mode to determine strict priority queues.
    device(port-channel-1)# qos queue scheduler strict-priority 4
    There are seven traffic classes. Specify the weight for the priority If the priority is in WFQ mode.
  4. Return to privileged exec mode.
    device(port-channel-1)# end
  5. Verify the configuration.
    device# show qos interface port-channel 1
  6. View the VOQ statistics.
    device# show tm voq-stat ingress-device ethernet 0/15 egress-port ethernet 0/125
    VOQ-Counters:
    Priority 0
    EnQue Pkt Count                          0
    EnQue Bytes Count                        0
    Total Discard Pkt Count                  0
    Total Discard Bytes Count                0
    Current Queue Depth                      0
    Maximum Queue Depth since Last read      0
    Priority 1
    EnQue Pkt Count                          0
    EnQue Bytes Count                        0
    Priority 2
    EnQue Pkt Count                          0
    EnQue Bytes Count                        0
    Priority 3
    EnQue Pkt Count                          0
    EnQue Bytes Count                        0
    Priority 4
    EnQue Pkt Count                          0
    EnQue Bytes Count                        0
    Priority 5
    EnQue Pkt Count                          0
    EnQue Bytes Count                        0
    Priority 6
    EnQue Pkt Count                          0
    EnQue Bytes Count                        0
    Priority 7
    EnQue Pkt Count                          0
    EnQue Bytes Count                        0
  7. Save the configuration.
    device# copu running-config startup-config
QoS egress scheduling configuration example
