Perform the following steps to configure LSF globally or on an interface.
From privileged EXEC mode, access global configuration mode.
device# configure terminal
Globally change the LFS, if required.
device(config)# link-fault-signaling rx off tx on
In this example, the global LFS is disabled for the link fault RX and enabled for link fault TX.
Access the interface configuration mode for the port that you want to configure.
device(config)# interface Ethernet 0/1
Shut down the interface.
device(conf-if-eth-0/1)# shutdown
The interface must be in the shutdown state before you disable or enable TX LFS.
Change the LFS for the interface.
device(conf-if-eth-0/1)# link-fault-signaling rx on tx off
In this example, the LFS for the interface is enabled for the link fault RX and disabled for the link fault TX. This configuration on the interface overrides the global configuration.
Enable the interface.
device(conf-if-eth-0/1)# no shutdown
Verify the configuration for the interface.
device(conf-if-eth-0/1)# do show running-config interface ethernet 0/1
no shutdown
The following example shows the steps in the previous configuration.
