This topic describes how to install and start TPVM using the deploy config command and persist other TPVM configurations in the SLX-OS running-config. These persisted configurations are useful during the TPVM upgrade operation. Also, for SLX switch RMA use case, TPVM can be deployed with previous configurations, as per the SLX RMA workflow of restoring SLX configurations.
Pre-requisite for deploy:
The TPVM debian image file (e.g. tpvm-4.2.5-1.amd64.deb ) is available in the following folder /tftpboot/SWBD2900. To deploy, install this file with this naming convention.
Only one file can be stored in the above mentioned location.
Example 1) This example describes a simple deploy action with TPVM built-in defaults.
SLX # config terminal
SLX (config)# tpvm TPVM
SLX (config-tpvm-TPVM) # deploy
SLX (config-tpvm-TPVM) # end
  • The deploy command is a time-taking operation. If executed through the Netconf/RPC, it is non-blocking to the client and will proceed in the background at the SLX switch. The Raslog “DCMD-1451” (for start), “DCMD-1452” (for success) and “DCMD-1453” (for fail/abort) are published.
  • TPVM image significant defaults are:
    • hostname – ‘tpvm‘
    • timezone – ‘Etc/GMT
    • management - 'dhcp'
    • password for user ‘extreme‘ – ‘password‘
    • dns -
    • ntp – no setting
    • ldap – no setting
    • trusted-peer – not set
Example 2) This example describes deploy TPVM with install time configuration. The TPVM config password, interface management can be set only before 'starting' or 'deploy' of the TPVM.
SLX (config-tpvm-TPVM) # password newpassword
SLX (config-tpvm-TPVM) # interface management ip 10.25.24.21/24
Example 3) This example describes the deploy TPVM and later 'updates' and 'any install time' configurations.
SLX # tpvm stop
SLX (config-tpvm-TPVM) # password newpasswordagain
SLX (config-tpvm-TPVM) # interface management ip 10.25.24.221/24
SLX # tpvm start
Example 4) This example describes the config TPVM with any install time or runtime configuration without deploy. The configuration here is just persisted in the SLX running-config database. The Runtime configuration is applied anytime before or after deploy. In the later case, the TPVM will be in the running status and configuration is applied to the TPVM instance first. Only upon success, the configuration will be persisted at the SLX-OS database.
SLX (config-tpvm-TPVM) # auto-boot
SLX (config-tpvm-TPVM) # hostname newhostname
SLX (config-tpvm-TPVM) # timezone Europe/Stockholm
Later TPVM may be installed and started with the above configuration by config deploy.
Example 5) This example describes the deploy TPVM with some configuration and later update any runtime configuration.
SLX (config-tpvm-TPVM) # hostname oldhostname
SLX (config-tpvm-TPVM) # no timezone
Example 6) This example describes the set password configuration using the encrypted string. Here the newpassword encrypted string is used.
SLX (config-tpvm-TPVM) # password $6$M@T]Ip^<$.kavoRt.uINQoghhcpDYd4elQg3BWWuJDdVSmGtZcM/Ry6IRUYKkKtJ80PgTXKFEVnzWx4oTSPvHPRtvqXtGf/
Example 7) This example describes the stop and uninstall TPVM configurations and also by using the no deploy but retain configuration.
SLX (config-tpvm-TPVM) # no deploy
Example 8) This example describes the stop, uninstall, no deploy and purge all TPVM configurations.
SLX (config)# no tpvm TPVM
SLX (config) # end
Example 9) This example describes how to reset any individual configuration, by using the no prefix command, and certain configurations may have parameters too.
SLX (config-tpvm-TPVM) # no hostname
