To configure LLDP interface-level command options, perform the following steps.
  1. In privileged EXEC mode, access global configuration mode.
    device# configure terminal
  2. Access the interface configuration mode.
    device(config)# interface Ethernet 0/8
  3. Apply an LLDP profile to the interface.
    device(conf-if-eth-0/8)# lldp profile network_standard
  4. Return to privileged EXEC mode.
    device(conf-if-eth-0/8)# end
  5. Save the running-config file to the startup-config file.
The following configuration is an example of the previous steps.
