FIB compression
FIB compression is enabled for IPv4 and IPv6, supporting up to (approximately) 5.7 M IPv4 routes and 900 K IPv6 routes. Refer to release notes and scale documentation for further information.
Note the following:
Compression limitations
Compressions can save hardware resources. However, FIB compression can result in the following:
  1. Because compression requires a parent route with the same next-hop, Level 1 routes cannot be compressed, as they may not have a parent route (default route).
  2. Level 1 routes in the Internet BGP FIB can be compressed in the range of 40% to 50%.
