To restore the default configuration, perform the following procedure in privileged EXEC mode.
  1. Enter the copy default-config startup-config command to overwrite the startup configuration with the default configuration.
    device# copy default-config startup-config
  2. Confirm that you want to make the change by entering Y when prompted.
    This operation will modify your startup configuration. Do you want to continue? [Y/N]: y
  3. Reboot the device.
    device# reload system
